friday88
- Aug 13, 2018
- 5
I need to assemble a 1/8" flexible cable into an #8-32 aluminum coupling that will have a screw fastened to it's other end. The purpose of this is to create a flex shaft allowing the screw to be turned remotely while access to the screw head is limited.
The challenge I'm facing is finding a permanent attachment method for the steel cable and the threaded coupling. I first attempted #6-32 set screws through the side of the coupling, but they failed after short use, and torquing them tighter sometimes stripped the allen heads. I believe an epoxy adhesive may be the solution, but I'm not experienced with these types of adhesives.
I plan to experiment with JB Weld's original 2 part epoxy product, but I'm wondering if anyone knows of a more specialized adhesive for this type of situation?
It needs to be as permanent as possible, and must be able to withstand temperatures of up to 250 degrees Fahrenheit.
thanks
thanks
