struclearner
- May 8, 2010
- 122
For structure under bending loading, strain gauges are placed at the top and bottom, or across the wall of the structure member depending upon the bending mode, and the strain gauges data showing tension on the top and compression on the bottom verifies the loading type as bending.
What are the Bending Strain and how these can be calculated from axial strains?
For example, in the case of determining stresses on the bolts, 4 strain gauges are placed on the bolt shank, around the periphery, in case of tensile loading, all the strain gages output will be axial strain, in case of bolt bending, how the bending strain of the bolt will be calculated.
Thanks a lot for your insights and help.
