jesseg010
- Jul 29, 2019
- 2
ok so maybe a {NOOB} question but okay.
depending on type of metal (examples below) is their a standard or a great reference (for tolerance change) to keep by my side when thickness and number of bends change? for example taken into account thin material allowing for spring back, or thicker hot rolled material. Please get back to me if my question wasnt clear. this would mean a great deal to me thanks again.
2.1 #1. Stainless steel sheets metals
2.1.1 Stainless steel sheets Use
2.2 #2. Copper sheet metals
2.2.1 Copper sheet metal Uses
2.3 #3. Brass sheet metals
2.3.1 Brass sheet metals Uses
2.4 #4. Corrugated sheet metals
2.4.1 Corrugated sheet metals Uses
2.5 #5. Galvanized sheet metals
2.5.1 Electro-Galvanized sheet
2.5.2 The hot-dipped metallic coated sheet
2.5.3 Galvanized sheet metals Uses
2.6 Other Minor types of Sheet Metals
2.6.1 #1. Cold Rolled Steel Sheet
2.6.2 #2. Hot Rolled Steel Sheet
2.6.3 #3. Mild Steel Sheet
2.6.4 #4. Aluminum Sheet Metals
