motorworks
- Sep 30, 2001
- 23
Hi
I am hoping someone may be able to help
I have a shaft on the end of a roller that is 100 mm
in diameter and I need a bearing/pillow block to fit it.
The problem is the area where the bearing goes is
8" wide by 8" high by 4" thick.
I have been throught most of the books and all are
too big.
Fairly heavy load,slow turning,near salt water and sea mud.
(sea wall roller on the back of a deep sea dragger)
We are now using SAE 660 bushings* in split blocks, but only getting 4-6 months out of the bushings
*bushing are 100 mm x 120mm x 95mm
take care
eddie
too big.
take care
eddie
