Bearing Capacity of Asphalt Pavement
JohnPezl
Is there a methodology or formula to approximate the bearing capacity of an existing asphalt pavement, for the purpose of supporting construction equipment movement and cranes?
The proposed bearing pressures can be reduced with the use of mats and plates, but need to determine what the probable existing pavement capacity is.
