basic vba question
MerolaAlba
Automotive
Oct 19, 2017
12
Hi everyone,
I have a basic vba question.
I recorded a macro in CATVBA that allows the user to select a specific CATPart in an assembly, I'm going to insert it in a GUI via VBA editor to make a Slider "graphical menu" to speed up process of going up and down the spec tree and to make it attractive to management ;-)
I'm trying to alter a user selected parameter of a selected CATPart in an assembly via CADSelection. I've recorded the macro several times and tried to incorporate oSelection in several places and tweaked around with this for a while now, but i can't seem to finish this.
Am i declaring oSelection in the incorrect place, or am i missing something else?
My tree is:
Product;
-Part;
-Part_Teste_2;
-Part_Teste_3;
-Part_Teste_4;
-Part_Teste_5;
All of the above "Part_Teste" have 3 parameters one of them is called "Comprimento"
How do I change make sure that the macro alters the selected CATPArt's parameter instead of ("Part_Teste_3.CATPart")?
The macro that I have so far is:
Code:
Language="VBSCRIPT"
Sub CATMain()
Set oProductDoc = CATIA.ActiveDocument
Set oProd = oProductDoc.Product
Set oDocs = CATIA.Documents
Set oSelection = CATIA.ActiveDocument.Selection
If oSelection.Count < 1 then
    MsgBox "Pick some components using cad selection.","No components were selected"
Else
    Set oPartDoc = oDocs.Item("Part_Teste_3.CATPart")
    Set oPart = oPartDoc.Part
    Set oParam = oPart.Parameters
    Set oLength = oParam.Item("Comprimento")
    oLength.Value = 50.000000
End If
oSelection.Clear
oProd.Update
End Sub
just try something like this:
Code:
Else
    Set oPartDoc = oSelection.Item(1).Value
End If
If you would like to change parameter for more selected elements, then you have to call your code in loop.
Tesak
- Text along a curve for Catia V5
Hi @tesak,
Thanks for your reply.
I get the following error on this line:
The object doesn't support this property or method.
Code:
Should I be declaring oPartDoc somewhere above?
Sorry I did mistake and I am mixing apples with pears (because I have no computer to test it). Try like this:
Code:
Else
    Set oPart = oSelection.Item(1).Value.ReferenceProduct.Parent.Part
End If
You do not need document oPartDoc at all, because from selection you should get your part directly.
Tesak
@tesak
Using your suggestion and a For Loop i was able to get the code work.
Here's the updated code in .catvbs
Code:
Language="VBSCRIPT"
Sub CATMain()
Else
	Dim I
	For I = 1 To oSelection.Count
		Set oPartDoc = oSelection.Item(I).Value.ReferenceProduct.Parent
	Next
End If
oSelection.Clear
oProd.Update
End Sub
With it i can select any of the CATParts (using cadselection in the spectree) and provided that they have the parameter
"Comprimento" in them it will update the CATPart accordingly.
In the 1st attachment is a prtscr of the spec tree:
Link
1 - CATProduct;
1 - CATPart;
4 - CATParts:
Part_Teste_2;
Part_Teste_3;
Part_Teste_4;
Part_Teste_5;
Each of these has 3 Parameters:
Comprimento (Length)
Largura (Width)
Altura (Height)
In the 2nd attachment is a prtscr of what the menu is and how it should work.
Link
Now "all that's left", is to transfer that specific code to the catvba project, make appropriate changes and link it to the respective textboxes in the VBA Project.
Anything i should avoid doing, or do you have any advice on how to proceed further?
I think you are on a good way. You can perhaps make it more robust by adding some error handling (if it is going to be used by more users), but it works and this is important. With VBA and user interface you make it pretty and user friendly which is always good, especially if you need to present it to somebody :).
Tesak
