Balloons
Poorpaulus
Automotive
Feb 3, 2002
89
On an Assembly drawing, I am having problems selecting all of the components on the screen when I am trying to put balloons on them. They are showing in the BOM table, but when I click on the part, it clicks "through" it and selects the part behind it.
Why?
Paul.
Is the assembly on the drawing in an exploded view? If so, I have worked around the problem by making the view un-exploded. Then I hide parts til I can see the part I want to balloon. Attach the balloon and then set the view back to exploded again and un-hide the parts.
Make sure you place the balloon pointer on the part where you want it when it goes back to the exploded view. If you try to re-position the pointer on the part after it has been exploded again it will become dangling and you will have to go through the process again.
I see this happen on only a few of my assemblies. Hopefully this helps you with the problem you are having.
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2006 SP0.0
Does the RMB click & Select other not give the alternative selections.
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Sorted.
Yes, it is an exploded view.
Having the assembly in the same state as the drawing seems to work.
Thanks for your help guys (and gals if applicable).
