D
dsrobin
Guest
I have (2) intersecting lines. I want to perform the move command and move a set of lines to the end of the perpendicular line (basically changing the intersection of (2) walls). I have OSnaps turned on and Intersections selected. When I pass over the intersection, the cursor snaps to the end of the line not the intersection.
It appears that the lines may be in different planes, but the "z" values are both 0. I can trim either line on any side of these lines so they do intersect, I assume.
Please provide feed back on how to address this issue.
Thank you in advance for any assistance.
