AUPREC
boldfish
101
Angular Unit Precision setting. What is it for?
The Linear counterpart setting is reflected when using DIST command. Where would I see the results of the AUPREC?
when you list an entity the angular result will change with this setting ie:line angles, arc start and end etc
Used usually to control accuracy when programming autocad. If the precision is low, drawing lines emanating from a point to the next point, to the next point, etc... and then back to the beginning may be off.
"Everybody is ignorant, only on different subjects." — Will Rogers
