Associative bom table to excel
  • Thread starter Thread starter jbuckl
  • Start date Start date
J
jbuckl
Guest
I havean assembly drawing with a table showing all the part info, like a b.o.m.
How can i export this table as an excel file ( or import it to excel)
pretty sure this info is here but my search didnt work
Jbuckl
Edited by: jbuckl
The way i do it (and i'm sure some dork will bite my head off!
) I save the table as a text file. open a new excel work sheet and excel will walk you thru setting up the columns and such.
Hi Jelston, thanks for the reply.
I managed to get a sensible looking excel sheet of the bom, and found a similar thread.
The thread advised using the intralink report because the configuration is editable, it did give a better result than the pro-e bom.
The icing on the cake would be a associative / parametric excel bom.
I suspect a bolt in package would be required......anybody know how an associative excel bom can be created?
The best option I found in Proe Wf3is the next:
First select the table: click on the table, then go to menu "table"-->select-->table
then go to "table" menu--> save table-->CSV file
Using the explorer of your computer, search your xxxx.csv.1 file, and modify theextension as a .txt: p.ex: xxxx.csv.1-->xxxx.txt (accept the advertising of windows)
then open microsoft excel, and then: file-->open your xxxx.txt
press next, select only "comma" and you will have a perfect document!!
I supose it will runs! good luck!
Ferran
Thanks Ferran,
Im on WF2 but I'll try that anyway. Not sure csv is an option in WF2!! (
Does it stay associative by the way?
hey jbuckl!
In Wf2 the option csv doesn't exist,
in WF2 you can only safe as a txt, it means that you need to add columns in your table:
after each parameter columnadd a column that contains a comma.
name/comma/qty/comma/description/comma
it will suplies the CSV of WF3...
A bad thing is that the export to an excel is not associative... you have to doa newexcel each time you change the table of the drawing... I'm sorry
See you!
Ferran
Pro/E doesn't have excel associativity with excel in the base package, you can buy nitro-bom for about $4 grand. Solidworks, however, does have excel associativity.
I wish that the drawing was the controlling document in this case......
Know what I mean?
Ps Soiledworks probably needs excel!
Pps proe can export analysis to excel w/o nitro glyceryne!
Thanks for your help with this &
Take a look at this:-
[url]http://www.mcadcentral.com/proe/forum/uploads/cdtoad/2008-06 -11_101959_Intralink.zip[/url]
or
[url]http://www.mcadcentral.com/proe/forum/forum_posts.asp?TID=37 210&PN=1[/url]
I wish I could write in m/s/v/b.....wheres agood place to learn?
Ferran
I stand corrected, comma delimited works beautifully!
jelston has given a great CSV
Now it is much better to convert to Excel
Actually, Pro/E desparately needs excel. Have you tried to enter data in the pattern table? It takes for freakin ever. The beautiful about SW (and the thing that sux about Pro) is it is completely windows based.
We don't really need excel in my case just the pms think so....I prefer the controlling document to be the drawing in most cases.
'Pasting' outa bom kills the associativity and thats what I wanted to get around, but then they'd probably want the controlling doc to be excel...not good
With every cad system i worked with there is stuff that cant be modelled.....except Pro-E... its just a shame its marketed by people who .....well I'msure you know where that was going.
The other beautiful thing about most other cads systems is the (commensurate) low price
These articles discuss a (free) Pro/WebLink program that can create a drawing
table directly from selected data in Excel, and vice versa. Part 1 discusses
transfers from Excel to a Pro/Engineer table, while part 2 discusses transfers
in the other direction.
[url]http://inversionconsulting.blogspot.com/2008/06/weblink-exce l-to-proe-drw-tables-part-1.html [/url]
[url]http://inversionconsulting.blogspot.com/2008/06/weblink-exce l-to-proe-drw-tables-part-2.html [/url]
No CSV files (or any other external files) to worry about. Direct transfer of
data between Pro/Engineer and Excel. Works in WF2 and most likely all Wildfire
versions.
Marc
I'm about to try this has anyone had any success with it?
Sam
