M
MB2011SD
Guest
I have updated the search_path_file so it will go to the directory that has all the parts for my assembly, but even after I did that, when I go to open my assembly, there are still a few items in "red" which I have to go retreive manually. All the parts are located under one directory, so I don't understand why I keep having this problem.
If anyone has any advice I would appreciate it.
Note: The .prt drawings that I need for my assembly, are located in "subdirectories" of one "main directory", but to me, even if it's in a sub-directory, it should still find the parts. In other words, I have one directory called "parts" (And I am telling CREO to look for what i need in "parts", but below that parts directory are sub-directories called "bearings, cylinders, etc".
Shouldn't it work with no issues? even if the parts are located in sub-directories below the directory I am telling CREO to go and look?
Edited by: MB2011SD
Edited by: MB2011SD
