assembly with a family table item and relations
  • Thread starter Thread starter puppet
  • Start date Start date
P
puppet
Guest
i have a small setup and in it , i have 1 part which can vary relative to its family table.
in the assembly i have some simple relations to drive some geometry relative to that family table part.
my question is how would i reference my family table part?
ie
length:cid_2 this dont work as the cid changes with each family table instance
basically i need to be able to switch the family table part to other instances and still have my driving relations work.
RegarDs
PuPPet
i kinda of by passed this problem but replaceing the family tree with some conditional statements
ie
if mod1 = 1
a = 20
b = 10
endif
if mod2 = 1
a = 2
b = 3
endif
then made a variable to set which version of the system i wanted. its a pain in the back side, and i am sure there is a simpler way of doing this. if anyone knows please help.
hey isar ur a genious :) hint hint
found out this has to do with inheritance
and should use iid instead of cid ..
but it still doesnt work
I am having the same issue. The inheritance does not seem to be updating. If I open the part that is inherited, the value is updated, but not through the inheritance using IID.
