Assembly Relation in CREO 2.0
  • Thread starter Thread starter PLQ
  • Start date Start date
P
PLQ
Guest
Greetings all,
I'd like to set the offset dimension of a plane in an assembly relative to a parameter of a part in the assembly.
In pre-CREO versions I knew the format and how to get the session ID of the part.
I'm betting the format hasn't changed.
Although, how to 'switch dims to get the session ID is another story.
How can I get the session ID of the part?
TIA,
PLQ
In the relations, just select the part, and get one of it's dimensions into the relations editor - that will give you the session id for the part.
Thanks!
I actually want to use parameter of the part, but your tip gets the session ID of it.
That was it.
In reality, it's much easier now, as the dim symbols show when editing relations.
PLQ
