H
hamer sikkel
Guest
<DIV =post>hello,
I'am new to this forum so I hope you could help me with a (big) problem I encounter:
how to use properly the search_path_file asset in de config.pro ?
I added the commandline: search_path_file
value: zoekpaden.text
my working space consist of the file zoekpaden.text and the correct config.pro file
I added the correct search lines in the zoekpaden.text files
I think the problem could be incorrect use of syntax.
Use Creo Elements 5.0, if someone with experience could assist me ?
thank you for help</DIV><BR clear=all>
