Assembly Drawings
  • Thread starter Thread starter Sikandar-h
  • Start date Start date
S
Sikandar-h
Guest
I have an assembly of 6 parts and i want make a drawing, showing how these parts are being assembled. Can anyone please help me with it......
IMO you should use exploded views!
Regards, DonChunior
Use cross section views, simp reps, bom and balloons.
drag the parts to wher you want them prior to each build and use snapshots to capture the view, then you've got a drawing as a story-board.
If you have the module, you can create a Process assembly that you can show each component being installed. The module was called Pro/Process for Assemblies. My license still states that but I'm sure with PTC's way of doing things, it's changed the name. It may even be incorporated into one of the newer packages.
use exploded view and use offset lines to show the connections :)
