Assembly colors
  • Thread starter Thread starter glemieux
  • Start date Start date
G
glemieux
Guest
How do you set a particular color to a whole assembly or subassembly?
hello
View>Model Set Up> Model and Appearance.
Choose on one color (except the default entry) > Modify.
From the basic Toolbar > click on the color> change the R,G,B, parameters from there, or you can change the color from the Color Wheel
I think this helps you
xcad
In addition to what xcad says:
If you change the Set Object Appearance drop-down to Components - then select all the parts - you can apply the colour to all parts in the assembly.
Note - Use Sel by Menu > Sel All to pick all the parts in the assy.
Ed
