ASME VIII Div 2 meaning of b - unit width - for non circular vessel
Astronoza
Aerospace
Referring to ASME VIII div.2 §4.12.11.1 Nomenclature what is 'b'?
For calculation of I1 = Moment of Inertia of strip thickness t1 (t1 = short side plate thickness)
b - unit width per cross section. In the equations for the areas, moments of inertia, and bending moments for all vessel configurations without external reinforcements are given for cross sections with a unit width
I'm confused, is this overall width of the cross section or is it a depth? What does it mean by strip thickness?
 https://files.engineering.com/getfile.aspx?folder=f57fb636-9f1b-4c75-b2eb-897b7a6f66f5&file=type_3_non_circular_pressure_vessel.JPG
It is the overall width of the cross section, depth has no meaning in this case.
When calculating the Moment of Inertia, (b*t^3/12), t is the section thickness and b is the section width and for the cases of non-circular vessels without external reinforcements, the Moment of Inertia shall be calculated for a strip with a width of 1.0.
See PTB-4, 4.12.1.
Thank you!!!! @IdanPV
Wow I can't believe I hadn't looked at at PTB-4.
best regards!
