ASME Sect 1 - Radial Clearance between vessel hole and nozzle outside diameter
rmillercwi
Materials
Jul 19, 2006
76
Trying to find the maximum allowed radial clearance between vessel hole and nozzle outside diameter. Ie, the max gap between the drum shell and a nozzle welded with a combination groove/fillet welds from both sides.
I did find a requirement in PW.16.6 that refers to figure PW.16.1 (AA) which is clear. However, that particular instance was referenced "Necks and tubes to and including NPS 6 attached from one side only".
This doesn't apply to me in this particular instance as I am looking at a connection that is to be welded on both sides.
I do have an idea of what it should be, just trying to find the official word on it
I assumed as much after digging. Thanks for the reply.
