Fran67
Industrial
- Jun 26, 2019
- 28
Good morning everybody,
I have a question about "design temperature" notion of a piping line.
If you consider a welded line with a "T" form:
- In the main branch, the process flow is minimum -150°C
- in the perpendicular branch, there is no flow because there is a plug*.
(See the picture attached)
Because the length of perpendicular branch is 5 meter, and because there is no flow in this line, we consider that the mini temperature at the extremity of the perpendicular line will not be lower than -30°C (mini ambient temp).
The minimum permissible temperature of the welded plug is -30°C. (located at the extremity of the perpendicular branch).
Tu summerize, we have a welded line with two different minimal design temperatures
The question is: what is the design temperature of the welded line? ("design temperature" mentioned in the documentation: calculation note / test procedure...etc)
-> If -150°C, there is a contradiction with the mini permissible temperature of the plug
-> If -30°C, there is a contradiction with the process temperature (-150°C)
Do you know if a chapter of the ASME or other code deals with this case?
Or do you know simply the response?
*The plug is a special plug for this specific case of process application
Thank you for your return,
Fr67
Fr67
