Hydroxide01
Chemical
We are installing a new internal gear positive displacement pump for conveying slightly viscous, non hazardous liquids (100-500 cSt). Flow required will vary from 100-200 gpm, depending on demand, and will be modulated through a downstream control valve (a pump VFD to modulate flow will not work for this application). Due to the nature of a PD pump, if the process is only calling for 100 gpm, the PD pump will continue to build system pressure as it is designed to output 200 gpm.
We use a non ASME code, external pressure relief valve to limit pump discharge pressure that works quite well. I'm wondering if we need to be using a coded ASME valve in conjunction with this non code valve. B31.3 does not cover over pressure protection of pumps. B31.3 does say to reference Section VIII (pressure vessels) for selection of a pressure relief valve if one is required. However, in this case, I'm not worried about the piping over pressurizing. If an over pressure event were to occur somehow, the pump couplings and/or seal would fail before any pipe or piping component would fail.
Thoughts on this?
Thoughts on this?
