ASME.BPVC.VIII.2-2019 choice of fatigue curves for Method B screening
tigny
110
In ASME.BPVC.VIII.2, 3.F.1.2 there are the following qualifications, when selecting fatigue curves to apply to materials:
ASME.BPVC.VIII.2-2019 3-F.1.2 said:
(a) Carbon, Low Alloy, Series 4XX, High Alloy, and High Tensile Strength Steels for temperatures not exceeding 371°C
(b) Series 3XX High Alloy Steels, Nickel–Chromium–Iron Alloy, Nickel–Iron–Chromium Alloy, and Nickel–Copper Alloy for temperatures not exceeding 427°C
1) Do 17Cr-4Ni-4Cu, or 13Cr-4Ni composed steels fall under "High Tensile Strength Steels" (as stated in 3-F.1.2 a)) or "Nickel–Chromium–Iron" (as stated in 3-F.1.2 b))?
Any input about this would be appreciated. Are there pieces of information in the Code about this?
2)Does the "High Tensile Strength Steels" pertain to Carbon Steels only?
best regards,
My two cents regarding question number 1:
I think you should not use 3-F.1.2(b).
The composed steels you mention are Precipitation-Hardening Stainless Steels so you may not use the curves for 3XX High Alloy.
Hope that's helps.
Hi IdanPV,
thank you for your answer.
The 17Cr-4Ni-4Cu is a PH steel indeed. I'm inclined to go to the (a) curve.
The 13Cr-4Ni is a martensitic chromium steel. Because of its high tensile strength I have doubt about this classification.
I anyway used the conservative assumption to make the screening with the 3-F.1.2)(a) curve.
