ASME BPVC Section VIII.2 Clause 4.3.12 Vs VIII.1 UG-32(g)
PVDEngg
34
Hello all,
Conditions of applicability for using DIV.2 rules for design of toriconal sections 'paragraph 4.3.12.2' are listed in equations 4.3.63, 4.3.64 & 4.3.65. These conditions of applicability are specified in UG-32(g)in DIV.1, together for toriconical heads and sections. Is it coherent to compare these conditions of applicability in Div.1 & Div.2 with each other, as Div.2 is rewritten from Div.1 (not all rules though, can this one)? Question is what is reason Div.2 allow smaller knuckle radius (1.5% of connecting shell or head skirt OD) as compared to Div.1 (6% of connecting shell or head skirt OD)? Any background information?
Thanks in anticipation, for enlightenment.
The development is fully described (with appropriate references given) in ASME PTB-1.
For future reference, if you are ever wondering why rules are as they are in Div 2, ASME PTB-1 should be your first place to check.
Thanks for your guidance, sir. I shall follow that advise every next time. After you advised, I checked it in PTB-1, it does not mention anything specifically about conditions of applicability as such. It directs to WRC-521, Pressure Area Method Application to Knuckle Joint and stress analysis method for discontinuity stresses. Basically, does not seems to address 'rewrite of conditions of applicability FROM UG-32(g) of Div.1 TO equations (4.3.63, 4.3.64 & 4.3.65) in paragraph 4.3.12.2 of Div.2. Some of the members of this forum, like you, sir, are esteemed ASME BPVC Code Committee members. So, apart from literature study, a second place to seek answers to such specific questions where probability of getting accurate solution is high because of participation in code evolution.
Requesting comments.
Thank you.
The background information is provided in the WRC Bulletin.
Basically, new research was performed to validate the VIII-2 rules. At that time, there was no interest in updating the VIII-1 rules. And with Code Case 2695 (and the upcoming changes to the VIII-1 for the 2019 Edition) there is the availability to use the VIII-2 rules for VIII-1 construction. it is highly doubtful that the VIII-1 rules will be updated - it is more likely that they will actually be deleted and a referral/reference provided to VIII-2.
Thank you for to the purpose resolution sir. To conclude this, we can say that these particular requirements from two divisions should not be correlated.
