Raai2015
Chemical
- Jun 21, 2008
- 61
as per ASMe B31.1 ; cl:122.4 on attemperator block valave ''regulating valve shall be installed upstream of the stop valve. In additon, if the steam generator supplies steam to the steam turbine, a power operated block valves shall be installed upstream of the regulating valve."" - this is self explanatory as i am working on EN boiler and i am looking for the same or equavalent sentence inorder to install the manual operated or block valve.
