SUB23
- Feb 28, 2020
- 5
I have a question regarding ASCE 113’s base plate design. How do you go about calculating the effective length of the bend line (beff)? On page 103 of the 113 manual, a brief method for finding beff is given – “(beff) is assumed to be limited by the distance between the projected length of the first and last bolt acting on the bend line plus the sum of the perpendicular distances from these extreme bolts to the bend line.” So if I have a 4 bolt pattern at 12”x12” and I am using an HSS8x8 column I would have the following effective bend line length for the bend lines at the faces of the column...
beff = 12”(projected length of the first and last bolt acting on the bend line) + 2*2”(sum of the perpendicular distances from these extreme bolts to the bend line) = 16”
However, how would I calculate the beff for the “diagonal” bend line across the corner of the column? Since there is only one bolt acting on that bend line, would I just use 2 times the perpendicular distance from that bolt to the bend line? So in my case above, beff = 2*(sqrt(2)*2”), which seems very small.
Thanks!
Thanks!
