Tomfh
- Feb 27, 2005
- 3,624
AS4678 Earth Retaining Structures requires you factor the soil material properties (eg friction angle) when calculating earth pressures. In turn you only need to factor the active Earth Pressures by 1.25 instead of 1.5
AS4678 comments that this results in equivalent Active earth pressure factors in the order of 1.3-1.7, which is consistent with AS1170's previous approach of factoring by 1.5. I.e. you get similar results both ways.
That's all well and good for Active Earth pressures, but for walls that rely largely on passive pressures to resist overturning the AS4678 approach appears to result in completely different designs, because it punishes your Kp passive pressure factor, but doesn't compensate in any way.
Am I right about this? Am I missing something?
