arena-vba
b3b3
Industrial
Jan 8, 2004
1
I am working in Arena 5.0 . I have .doe file in which I wrote VBA code for the process diagram( process diagram is not done by me). I want to run the simulation for Number of groups. In the process diagram there are VBA blocks which are defined for each week. Previously I ran arena each group separately giving exel input files(example week1.xsl,week2.xsl). Now I require to run model for several groups simultaneously one after another and outputs are wrote into excel files as g1out.xsl, g2out.xsl respectively. The problem I encountered is there is some output template open and is not saved until arena is stopped for each group. Do I require to make changes in design diagram for assigning new VB-block for running model for several times.
I truly appreciate any suggestions.
