Arc-aligned text
  • Thread starter Thread starter Krantha
  • Start date Start date
K
Krantha
Guest
I aligned text to the inside of an arc. I need to explode the text to individual letters so I can rotate the letters for appropriate spacing. When I try to explode the text it turns the text upside down and reorientates it to the outside of the arc. Any ideas on how to fix this?
Go to "Draw>Circle>Center,Radius" menu and then draw a circle and then go to Miscellaneous>Curved Text on circle" menu and when prompted to select the center point of the circle just right click on the mouse and then select "Center" from the context menu now you would be prompted to select the midpoint of the text just pick a point inside the circle where ever you want and then enter the text the you want to. I hope it was useful.
Thanks for the reply. It did work.
