K
ksarita20
Guest
hi ,
i have a problem of how pro/e is intrepreting the bearing loads. Can anyone help me out.
i will give a brief explination of the problem.
i have a rod with 3 holes at the the bottom at 120 degrees apart. i have to apply a load of 337.5 on the whole structure which is distributed on to the 3 holes. So i applied 112.5 as bearing load on eachhole. And when i apply 337.5 by seleting all the 3 holes at a time, the stress are 3 times to what i got when applyng 112.5 on each hole.
So i confused which one is right and how pro/e is considering bearing loads.
PLease help me out , i am stuck!
thanks
Sarita
thanks
Sarita
