API 610 Annex-G
MohdYaseen2010
101
Dears;
I am querying about selection of the right Material Class for pump delivering a condensate oil fluid flowing from our Flare Knockout Drum to our Drain sump; the flared gas coming to the drum is produced from sour crude in the separator.
Annex G didn't specify such service, so I confused which Material Class should I select?
on other hand, for the same setup we have sweet crude producing flare gas going to Flare Knockout Drum; what the Material class should I have select for the pump delivering the condensate oil to our Drain sump?
Mohd Yaseen
