Any common industry uses for boride diffusion coatings beyond wear?
YungPlantEng
Chemical
Jan 19, 2022
94
I’ve seen sparse details on the chemical compatibility of FeB coatings, especially when aqueous corrosion consideration when applied to high nickel alloys. Our process in a quench has both high temperature and dew point corrosion failures related to sulfuric acid with high chlorides.
