R
rbarata
Guest
Hello, my friends
Another exercise...I need your oppinion about how to do it. To create the part in the attachement, as far as I can see, I will need 3 sketches: one with the left side of the part (excluding the R31.8 mm semi-circle), another to the right side (again excluding the R31.8 mm semi-circle) and a third only with the R31.8 mm semi-circleto.
My strategy will be to extrude a 16 mm pad using the first sketch, extrude another pad with 48 + 16 mm using the second sketch and with the third sketch (constructed on a plane defined by the upper face of the 48 + 16 mm pad) I will create a pocket of 28,6 mm depth.
About the 30º angle on the upper face, haven't thought about it that much but there are several ways to do it (for ex, using a fourth up-to-plane sketch, or cutting the top face with an intersecting plane, etc, etc).
My main concern for now is the first part of my post. What do you think about my strategy?
Thank you
Thank you
