Angular Dimensions
  • Thread starter Thread starter Den E
  • Start date Start date
D
Den E
Guest
Hey there, Pro/E gurus.
I'm trying to dimension an angle that is less than 1 degree, but Pro/E refuses to let me create the dimension. Maybe I need to set something in drawing options, but I can't find it.
We are using Wildfire2.
Thanks in advance.
Den E
Hi Den,
In your sketch draw the angle exaggeratedly large, then change the value to what you need it to be. Then show/erase>sho this on the drawing. Have you tried that?
Sip
Further if you want the angle to STAY PUT, LOCK it in while in sketch mode, so that proe knows your intentions in no uncertain terms and that you mean business.
Thank you, most excellent people.
It worked!
Den E
den there s a config option for this
minimun_angle_dimension
check this up
