B
bendesarts
Guest
How is it possible to make a constraint of an oriented angle in CATIA ?
It seems to me that when I use a angular constraint, whatever if I select the part 1 ou 2 in first (I want a angular constraint between 2 parts : part 1 and part 2), I obtain the same angle/
For 1 angular constraint (between part 2 and part 1 (taken as my reference), I didn't have the desired angle but the opposite ("-". Consequently, how can I do so that the angular constraint correspond to the oriented angle that I want ?
There are some other choices (angular sector1, 2, 3 ou 4) but i didn't manage to create the opposite of my angle.
I make the opposite of my angle for the moment by adding a "-" in a formula. But, I would prefer to make cleaner solution by defining exactly the oriented angle I want for the beginning.
Thanks a lot for your ideas.
