P1ENG
- Aug 25, 2010
- 237
I'm looking for some thoughts. I have an elevated tank with granular fill supported on concentrically braced columns (R=3, Omega=2). I have run the load combinations without overstrength and there is no net uplift (actually minimum compressive force is ~230 kip [(0.9-0.2SDS)*D+E]) and worst-case shear is ~45 kip.
I have determined anchorage for shear without overstrength, however there is no way to do ductile yielded plate (unless someone wants to enlighten me), so technically I should be using overstrength for shear. If I do that, then shear loads would be ~90 kip (45 kip * Omega).
Now for your opinions (or a reference to the code that will crush my dreams). Can the 50 kip capacity of the anchors be combined with the 230k*0.2 = 46 kip friction resistance (steel on concrete assumed mu=0.2) to satisfy the overstrength design? I've seen the friction question posed before, but it was always to resist 100% of seismic with no anchorage, so I didn't know what the community thought about using friction as a redundancy or to supplement the overstrength design.
Juston Fluckey, SE, PE, AWS CWI
Engineering Consultant
