pappyirl
- Oct 9, 2003
- 54
In designing a simply supported beam a scenario has arisen where there is a requirement to anchor 2 layers of bottom reinforcement at a column support with L bars, see attached sketch. It is probably similar to a situation which would arise on a deep beam close to a support, anchoring the longitudinal reinforcement without using mechanical anchors.
Is bearing stress inside the bend of a reinforcing bar an issue when there is another bar directly in front of it which exerting the same bearing stress although the bar bend location is slightly elevated due to spacers in the layers? Might be splitting hairs but any advice, code or otherwise is much appreciated.
