analysis notes on model
  • Thread starter Thread starter Uni Phil
  • Start date Start date
U
Uni Phil
Guest
I remember some time ago a video on proecentral explaining how to put analysis results of mass etc on your model which updated each time something was done.
Anyone know where I would find that or even have a tutorial on that please.
cheers
Hi Phil
I have an analysis feature with "MEASURE" as the name and DIST is a parameter (say between two surfaces); I would create a 3D note by having...
&dist:fid_measure
...... as text of the Note.
The result I would get is the value that resulted from the Analysis. And whenever I change the model in such a way that the distance between the surfaces(used in the analisys) changes, the note will up updated automatically
DN Reddy, Manchuri
how do you get the not to attach the model, so you can see it on the screen.
In 2001, "Setup > Notes > New" and create the 3D note as necessary.
in WildFire,you can alsouse a string parametr to create a datum cure(text).
for example:
make a datum curve,use "use parameter" option draw a text entity in sketcher,now the curve(text) will update auomatically with the parameter.maybe you should use itos() function t convert the parameter to string type.
Edited by: IceFai
I'm trying to increase the number of digits displayed in a note I created for an analysis feature. I thought adding [.5] to the text line would display 5 significant figures, but it doesn't. Any ideas on what I might want to try??
Thanks...
