analysis features not on the model tree
  • Thread starter Thread starter puppet
  • Start date Start date
P
puppet
Guest
should they not be on the modle tree? for some reason i can not see them after i make them.
anyone have any ideas
go to modelytee setup and display features on. But I think you need this thing in assembly mode. In part mode you should see these automatically.
Israr
thanks for that.
how do i these changes/settings to my config.pro? or where ever they should be?
model tree display
features on
notes on
suppressed on
i tried saving the file but it did nothing. put in the bin directory and the pro install directory all to no avail
thanks in advance .
PupPet
After making the changes to your Model Tree, Choose File>Save Settings in 2001. Save it as a name you will recognize in your startup dir. You can then retrieve those settings at a later time or you can add this option to config.pro:
MDL_TREE_CFG_FILE path to cfg file
