FoxSE14
- Feb 5, 2011
- 131
Hi All,
Please see attached sketch. I think we have successfully avoided situation #2 (bottom) where the shear plates and welds are exactly aligned on both sides of a column web, however, we ran into a close call earlier today that had a few of us sweating.
How often do you direct the detailer/fabricator to offset shear plates which connect to opposing faces of the same column web? If a detailer shows plates/welds aligned on a set of shops, do you direct them to change it such that the plates/welds are offset?
I'd like to think we would have been ok "in the real world" since we have 1/2" stabilizer plates above and below that would have assisted in force distribution, however, when we tried to quickly find references/guides directing to keep shear plates misaligned, none of us were able to quickly locate anything. Anyone know of the reference/code section where aligning welds on opposite sides of a column web is 'frowned upon'?
