ALIGN BROKEN VIEWS
  • Thread starter Thread starter bosch2Ls
  • Start date Start date
B
bosch2Ls
Guest
Does anyone know how to align the two sides of a broken view? My broken view is offset.
Thanks in advance.
Could you post a pic so we can see the drawing. I have never seen a broken view that is offset.
Here is the broken view offset. I could align it by inserting 2 views then do a partial view on both. I don't want to go that route.
<?:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /></v:stroke></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:ulas></v:path><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:lock aspectratio="t" v:ext="edit"></o:lock>
</v:stroke></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:f></v:ulas></v:path><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shape>
I am afraid that there is no way to fix the offset that I know of. Since it is an iso view, it breaks where you sktech and moves them closer at those breaks. It is just the nature of the beast.
Sachin - your part had the same problem. If you break a part it will not follow the angle, it only moves the 2 pieces together horizontally. Picture your part on a piece of paper. draw 2 vertical lines for the break. Now fold the paper over to where the 2 vertical lines meet. That is what the break command does. Break is good for long straight parts.
I would be happy if they include inclined break as solution
