AISC Slot dimensions 1
kaffy
CA
Hi guys,
The long slot dimensions for 3/4" bolt as per AISC is 13/16" x 1 7/8". My question is : Is that 1 7/8" from centre of hole to centre of hole or is it from very outside of slot to very outside (#1 or #2 as hown in attached file)?
Thank You
KD
 https://files.engineering.com/getfile.aspx?folder=f1f4b510-21a7-4c68-bcc7-040b983835bc&file=Slot_Dimension.pdf
Your figure on the left is correct.
