Adding symbols to the symbol pallette
  • Thread starter Thread starter maurya
  • Start date Start date
M
maurya
Guest
Hello
I would like to know..how to
1.Define a symbol so that I can use it in the Drawing.
2.Add the symbol so defined to the symbol pallette that comes with Pro/E.
You can create a symbol with the following ways:
Creating a symbol shame by drafting
To create a new symbol in a drawing:
Format | Symbol Gallery | Define and give it a name.
Sketch entities (lines, etc) or use existing entities - Copy drawing
To include variable text in a symbol note, place backslashes around it, eg: \text\ - this will allow you to change the text for each symbol placement
Attributes define how the symbol will be placed in a drawing:
- Placement - free, on entity, with leaders, etc
- Height - fixed, variable (related to drawing, view or text)
- Variable text values
Write the symbol to disk, for use in other drawings
To start a symbol palette, first create a drawing entitled palette.drw.
Next, insert your symbols into this drawing, scaling appropriately so you can see them
Add a line to your config.pro like this:
symbol_instance_palette_file c:\symbols\palette.drw
To place a symbol from this palette into a drawing, use Insert | Symbol Instance then Pick from Palette
See more at: http://www.geocities.com/proehelp/draw.htm#sym
http://www.geocities.com/proehelp/draw.htm#palette
Ed
Dear Karavasilis christos
At the outset Thank you very much for your elaborate answer.I will try out as you explained,and make a note of what happened.
You didn't mentioned your mail ID.Pl.do provide the same
Thank a lot once again
regards
maurya
Dear Ed
Thanks a lot for sparing your time to help some one who is in need.I'll come back to you soon
regards
maurya
