Adding Menus with JLink
  • Thread starter Thread starter newton126
  • Start date Start date
N
newton126
Guest
I have been successful so far in adding a custom menu to the main toolbar and adding a button to that menu. What I am struggling with is how to add a custom sub-menu to my existing menu.
Here is the code I have:
<BLOCKQUOTE dir=ltr style="MARGIN-RIGHT: 0px">
try {
curSession = pfcGlobal.GetProESession();
curSession.UIAddMenu("TopMenu1", "Help", "test.txt", null);
UICommand cmd = curSession.UICreateCommand("JL.HelpMenuApp",new MenuButtonListener());
curSession.UIAddButton(cmd, "TopMenu1", null, "SubButton1", "SubButton1Help", "test.txt");
curSession.UIAddMenu("SubMenu1", "SubButton1", "test.txt", "TopMenu1");
}</BLOCKQUOTE>
I'm basically trying to add a new menu called "SubMenu1" to main menu "TopMenu1". It compiles OK but when I start Pro/E, I only get TopMenu1 with SubButton1. SubMenu1 does not appear.
Any help is much appreciated.
Try this:
curSession.UIAddMenu("SubMenu1", "", "test.txt", "TopMenu1");
Then add your buttons afterward.
I have a top-level menu and 4 sub-menus, each with their own buttons. I add all the menus first, then the buttons later. The sub-menus appear at the bottom of my main menu.
Hope that helps.
Edited by: DanWolf
Thanks for the suggestion but it did not work. Same result.
I can add SubMenu1 to the top Pro/E menu and to other menus (like File or Windows). It just won't add it to TopMenu1.
I figured it out. You have to have a button added to the submenu in order for it to appear. I thought the menu would appear and I could add a button later.
