M
MichelvBst
Guest
The company I work for is (finally) transitioning to the latest version of ProE; Creo2
Currently we're working with Wildfire 2.
As a key user in my department I've gotten the opportunity to experiment with Creo already to get a head start.
One problem I encountered when creating a cast part (something we do a lot here) is that when defining a external copy geometry feature there is no "solid surfaces" option.
In Wildfire 2 you would just select one surface that you wanted to add to the copy geometry, hold down RMB and it would give you the option to select all the solid surfaces in the part.
Is there a way to do the same in Creo, am I missing something here?
