Supun93
- Nov 28, 2019
- 41
I'm working in a project where i need to strengthen a building to add 2 more additional storeys. Now it is just a single story timber frame building consist with timber 2x4 studs in 18" spacing. Exterior walls are load bearing shear walls and interior walls are non load bearing.
The problem is when i design the building for 3 storeys the ground floor walls require high resistance to lateral loads. I can have power trusses to increase the resistance but seems it is not economical. Is there a way to strengthen the walls without actually reconstructing the walls or do i need to demolish everything and work on it again. Please help
