Hi!
I am supervising the FAT of a Compressor Control System (CCS). The CCS vendor gave the flow measurement in deltaP (inchH2O) because they just need this to generate the H vs Q curves.
We required to show the measurement in actual and standard units using the actual pressure and temperature.
In order to do so, they will use some formulas to convert deltaP to actual flow. I don't know the details of the formulas but I assume they need MW, Z, Cp/Cv and gas viscosity. Those values are nowhere on their screens and are accessible for the operator to modify. However, the gas properties will change over time and from summer to winter.
My question is if you know how this is normally done for flow calculations? Do you think they have to show the gas properties and give an easy way to be modified by the operator?
Is it ok if the formula is just adjusted with actual pressure and temperature or the operator/engineer should change all the other gas properties?
I am struggling with this actual and standard measurement because I want a reliable flow shown in the screen but they only get deltaP and P/T downstream the orifice.
Thank you very much
Thank you very much
