Accessing SelectionSets using Catia VBA
hdwdlnd
Aerospace
Sep 1, 2009
16
I would like to resurrect an old thread related to selection sets and accessing them through VBA. Like the other poster I see the commands in the scripting documentation but I am unaware how to actually use them. Anyone out there care to share? Thanks.
working with selection sets is in fact quite easy once you know how to get SelectionSets object. This is what I find completely unintuitive, however, you can find some hints on google.
How it works
[ul]
[li]Open product[/li]
[li]Select some parts or assemblies and launch macro[/li]
[li]New selection set named "Example" is created & highlighted and it contains selection content[/li]
[/ul]
Code:
Sub Main()
    Dim doc, sel, setName
    setName = "Example"
    Set doc = CATIA.ActiveDocument
    Set sel = doc.Selection
    Dim selSets
    Set selSets = doc.Product.GetItem("CATIAVBSelectionSetsImpl")   ' get SelectionSets object (a tricky part)
    selSets.CreateSelectionSet setName          ' create new selection set
    selSets.AddCSOIntoSelectionSet setName      ' add selected elements to selection set
    sel.Clear
    selSets.PutSelectionSetIntoCSO setName      ' activate the content of selection set
'    Dim a()
'    selSets.GetListOfSelectionSet a
End Sub
However, I have a problem to get list of selection sets. Last 2 lines of code should work, but I experience CATIA crash on my machine when I uncomment them. But maybe it is only problem with my CATIA installation.
Tesak
- Text along a curve for Catia V5
Thanks for the help. The "CATIAVBSelectionSetsImpl" is what I was needing. I revised your code so that what items are selected in the tree get their own selection sets or the option to drop them in a named set which is why I was needing the script. Thanks again.
Code:
Sub CATMain()
Dim SelCheck As Integer
SelCheck = CATIA.ActiveDocument.Selection.Count2
Dim HCheck As String
If SelCheck = 0 Then
    MsgBox ("Items must be selected first")
    Exit Sub
End If
If SelCheck <= 1 Then
    HCheck = MsgBox("Are child components highlighted?", vbYesNo)
    If HCheck = vbNo Then
        MsgBox ("Hightlight items to be added and try again")
        Exit Sub
    End If
End If
Dim product1 As Product
Set product1 = doc.Product
Dim i As Integer
i = 1
Dim n As Integer
n = CATIA.ActiveDocument.Selection.Count2
Dim selSets
Dim NameCheck As String
Dim iSel As Selection
ReDim SelComp(n)
Dim Test As String
If CATIA.ActiveDocument.Selection.Count2 = 1 Then
    setName = sel.Item(1).Value.PartNumber
Else
    NameCheck = MsgBox("Do you want each item to have a selection set?", vbYesNo)
    If NameCheck = vbYes Then
        For i = 1 To n
            Set SelComp(i) = sel.Item(i).Value
        Next
        For i = 1 To n
            Set iSel = CATIA.ActiveDocument.Selection
            iSel.Clear
            iSel.Add SelComp(i)
            setName = iSel.Item(1).Value.PartNumber
        Next
    Else
        setName = InputBox("Selection Set Name", "Input Selection Set Name", sel.Item(1).Value.PartNumber)
    End If
End If
End Sub
You do not need to call these two lines as in my example:
Code:
sel.Clear
It is just slowing your script down (especially if you call it in a loop). For creation and adding content to selection set only following lines are required:
Code:
So you can save some resources and make your script shorter :).
Tesak
I see what you mean. I updated my code above so that it actually works now...I hope. I had botched a copy and paste or something last time. Where did you come up with "CATIAVBSelectionSetsImpl" if you don't mind me asking?
