Vig16
- Mar 21, 2007
- 67
We have an ABS part that undergoes accelerated age testing. The test is being ran at 56 degrees C for four months. We're finding that about 10% of the parts are snapping after the test is done. The part is a lever within a handle that is used to actuate certain pieces within the handle when the trigger is squeezed. There is a spring attached to the piece of ABS in the area that is snapping. Is this something that is caused by the accelerated age test? If not, what could be the problem?
