J
johnlkc
Guest
Hi there, I am facing one problem in my model. I follow the steps of a
movie clip to create a glasses but when I came to the freestyle 3D curve, I
can't get whet I supposed to get.
From the movie clip, the 3D curve can be moved in Z and Y directions
(showed cross shape translator) from 'front view'. And the curve can be
moved in X and Y directions (showed cross shape translator) from 'top
view'. So the curve can move in 3 directions.
Here is the problem, I use the creation type of 'through points' to
make a straight line. Then I need to adjust the line to make the shape
I want. But I can only adjust the shape of the 3D curve in only 2
directions (either XY, XZ, or ZY). That means the translator will only
appear as (cross shape) in 'front view' but will appear as (one horizontal line) in 'top view'.
I tried to free or constraint the point but It doesn't help me.. Please rescue me in this problem. Thank you.
In top View with X and Y direction can move.
in Front View with only can move in Y direction.
Problem: How to drag or adjust the 3D curve in Z direction? Help me please.......
