S
saikrishna
Guest
The design study terminated abnormally.
An error has occurred while requesting an additional
750 megabytes of memory from the operating system.
To correct this problem, you may need to increase the amount
of swap space on your system. You may also need to increase
the memory usage limits that are set for your system.
For large problems you can also try decreasing the
solram allocation setting.
At least 1.53102 gigabytes of memory are needed to run this design study.
<?:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" />
Documentation for this issue can be found in the Technical
Support Knowledge base at:
http://www.ptc.com/cs/tpi/128412.htm
For more information, you can search for the term "swap space"
in the <?:namespace prefix = st1 ns = "urn:schemas-microsoft-com
ffice:smarttags" /><st1
lace><st1
laceName>Help</st1
laceName> <st1
lace>Center</st1
lace></st1
lace>. To access the Help Center Pro/MECHANICA
topics, select #Help>#<st1
lace><st1
laceName>Help</st1
laceName> <st1
lace>Center</st1
lace></st1
lace>, set the functional area to
"Simulation" and then click on the "Structure and Thermal
Online Help" link.
Memory and Disk Usage:
Machine Type: Windows NT/x86
RAM Allocation for Solver (megabytes): 750.0
Total Elapsed Time (seconds): 580.13
Total CPU Time (seconds): 565.67
Maximum Memory Usage (kilobytes): 762716
Working Directory Disk Usage (kilobytes): 290816
Results Directory Size (kilobytes):
280998 .\desktop\testforasm
Maximum Data Base Working File Sizes (kilobytes):
290816 .\desktop\testforasm.tmp\kel1.bas
Run Completed with Fatal Error
<DIV style="BORDER-RIGHT: medium none; PADDING-RIGHT: 0in; BORDER-TOP: medium none; PADDING-LEFT: 0in; PADDING-BOTTOM: 1pt; BORDER-LEFT: medium none; PADDING-TOP: 0in; BORDER-BOTTOM: windowtext 1pt solid; mso-border-bottom-alt: solid windowtext .75pt">
<st1:date Year="2007" Day="23" Month="5">Wed May 23, 2007</st1:date> <st1:time Minute="29" Hour="12">12:29:39</st1:time></DIV>
<B style="mso-bidi-font-weight: normal">With increased swap size[/B]
2.70503 gigabytes of memory from the operating system.
At least 3.76998 gigabytes of memory are needed to run this design study.
in the <st1
lace><st1
laceName>Help</st1
laceName> <st1
lace>Center</st1
lace></st1
lace><st1
laceName>Help</st1
laceName> <st1
lace>Center</st1
lace></st1
Online Help" link.
RAM Allocation for Solver (megabytes): 7000.0
Total Elapsed Time (seconds): 272.67
Total CPU Time (seconds): 231.14
Maximum Memory Usage (kilobytes): 1039983
284637 .\desktop\testforasm1
290816 .\desktop\testforasm1.tmp\kel1.bas
<st1:date Year="2007" Day="23" Month="5">Wed May 23, 2007</st1:date> <st1:time Minute="4" Hour="13">13:04:08</st1:time>
PL ADVISE
Online Help" link.
in the <st1
Online Help" link.
PL ADVISE
