ABAQUS VUSDFLD subroutine 1
roya22
Dear all,
I'm trying to write a vusdfld subroutine to delete elements when their Mises stress reach a certain value. I set Depvar as 1 (for Mises stress). However, I don't know how what command I must use in the vusdfld in order to delete elements and where I must define Field variables in the model (I mean in Elastic in material module or somewhere else).
I would be really grateful if anyone could help me, as I'm new in using this subroutine.
best regards,
Roya
Sorry,
I read the mentioned discussion and modified myself. However, I got the error below:
The executable explicit.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist.
Here is the code:
subroutine vusdfld(
c Read only variables -
1 nblock,nstatev, nfieldv, nprops, ndir, nshr,
2 jElem, kIntPt, kLayer, kSecPt,
3 stepTime, totalTime, dt, cmname,
4 coordMp, direct, T, charLength, props,
5 stateOld,MISES,
c Write only variables -
6 stateNew, field)
c
include 'vaba_param.inc'
c
dimension jElem(nblock), coordMp(nblock,*),
1 direct(nblock,3,3), T(nblock,3,3),
2 charLength(nblock), props(nprops),
3 stateOld(nblock,nstatev),
4 stateNew(nblock,nstatev),
5 field(nblock,nfieldv)
character*80 cmname
c
c Local arrays from vgetvrm are dimensioned to
c maximum block size (maxblk)
c
parameter( nrData=6 )
character*3 cData(maxblk*nrData)
dimension rData(maxblk*nrData), jData(maxblk*nrData)
c
do k = 1, nblock
c
c Misses Stress
call vgetvrm('MISES', rData, jData, cData, jStatus )
c
MS=MISES(k,1)
stateNew(k,1)=MS
c
IF (stateNew(k,1).LT.5.76) Then
if (stateNew(k,2).NE.0) then
c Element deletion
stateNew(k,2)=0
else
stateNew(k,2)=1
end if
End IF
c
end do
c
return
end
Are there any problems regarding calling the mises stress?
You shouldn't change the subroutine interface so delete MISES from this line: 5 stateOld,MISES,
On github you can find an example of VUSDFLD subroutine used to delete elements above specified von Mises stress threshold. Search for AbaqusUserFieldDamage by BBurgarella.
Thank you so much for your guide and the example. It was really helpful.
